Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-05-2009, 12:05 PM
Skull_Splinter Skull_Splinter is offline
2000 Malibu Coolant Leak
My girlfriends Malibu has been leaking coolant, in the pictures the leak is to the left of the thermostat plug. It appears to originate near a bolt, at the edge of the intake manifold. She said that it's been leaking since she got the car and used to fill the coolant once every two months or so. It recently started leaking more and she would fill the coolant weekly. It doesn't seem to be leaking into the oil.
http://viewmorepics.myspace.com/inde...ageID=56503020
http://viewmorepics.myspace.com/inde...ageID=56503019
http://viewmorepics.myspace.com/inde...ageID=56503018
Old 12-05-2009, 12:51 PM
jd-autotech jd-autotech is offline
Re: 2000 Malibu Coolant Leak
its probably the intake gasket i have done a ton of them on the malibu 3.1 its very common.
Old 12-07-2009, 12:53 PM
sickcars sickcars is offline
Like JD said the leaking intakes are common problem with the 3.1. Anytime a customer complains about leaking coolant or the motor getting hot its the first place I look.
Old 12-15-2009, 02:10 PM
dpalomaki dpalomaki is offline
See the sticky thread on replacing the intake gasket (lower intake manifold) above for more than you are likely to ever want to know.
