Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-05-2009, 10:01 AM
mn90cherokee mn90cherokee is offline
1996 Saturn will not start
1996 Saturn DOHC 1.9 manual transmission.
When I try to start the car it will engage when the key is turned but only the one time and then stop. This behavior is consistent every time I attempt to start it.
I can hear the start attempt to crank and then just a whirring sound.
Any thoughts.
Old 12-06-2009, 02:21 PM
Cat Fuzz Cat Fuzz is offline
Re: 1996 Saturn will not start
Sounds like a bad starter solenoid.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 12-06-2009, 07:09 PM
RC1488 RC1488 is offline
+1. Hit the starter with a hammer and see if it gets it working again. New ones can be found on ebay
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 12-06-2009, 07:20 PM
OK I replaced the start and the CPS(I had some symptoms where it would not fire when trying to start so it was suggest that I replace that as well.
When the starter was replaced I tried to start the car. It took a while to actually fire and get running. Once it started it idles OK but when I attempt to give it gas it will sputter and misfire. I can here a loud sound like a bad muffler coming from the air cleaner box. I am unable to get it over about 2200 RPMs. It was running great before the starter failed 2 days ago.
I can start a new thread if necessary but I thought I would start here.
Old 12-08-2009, 09:19 AM
I rechecked all of my work on the starter and the CPS. Verified I didn't knock something loose . I pulled the plugs and they were black. I cleaned them off and reinstalled. Pulled the PCM B fuse for 5 minutes and restarted the car. It is now running as good as it used to.
I am guessing it was flooded and running rich which caused the black soot on he plugs, as well as on the ground under the tailpipe.
Old 12-08-2009, 10:53 AM
Replace your ECTS also
