Old 12-05-2009, 09:29 AM
rcksmpsn rcksmpsn is offline
94 lumina starting problem
Starting problem on a 1994 lumina euro 3.1, 150 k. Was running just fine when i got home and parked it. The next morning it would not start, battery is fine, have lights, radio, etc. The amp gauge jumps to the far right when i try to start it, but i get no start, no click. I did get it to start 1 time, but after shutting it down, nothing since. One strange thing i do notice is that i do not need to apply the brake to get it out of park and the steering wheel does not lock in park. Thank you, your help would be greatly appreciated, rick
Old 12-05-2009, 10:39 AM
maxwedge maxwedge is offline
A990 racer
Re: 94 lumina starting problem
Welcome to AF, not start means no crank correct? if so check the battery and all the cable connections, if ok check for 12v at the starter solenoid when attempting to start, 2 man job.
Old 12-05-2009, 11:16 AM
Smile Re: 94 lumina starting problem
The battery is new and all electrical components work. I don't even get a click when i try to start the car. I will check for 12v at the solenoid. Thank you!
Old 12-07-2009, 02:19 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
As MAXWEDGE said,"check all cable connections".
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 12-07-2009, 02:19 PM
Thanks, I have found no bad connections, still have to check for 12v at the solenoid as I need another set of hands. One strange thing I do notice is that I do not need to apply the brake to get it out of park and the steering wheel does not lock in park. This baffles me as all other electrical works, lights, horn, door locks, radio, etc., but the steering wheel doesn't lock and it always did before.?????
Old 12-07-2009, 02:24 PM
Thanks, I have found no bad connections, still have to check for 12v at the solenoid as I need another set of hands. One strange thing I do notice is that I do not need to apply the brake to get it out of park and the steering wheel does not lock in park. This baffles me as all other electrical works, lights, horn, door locks, radio, etc., but the steering wheel doesn't lock and it always did before.?????P.S. A new battery was installed approx 12 hours before this problem occurred.
Old 12-07-2009, 06:32 PM
svotta svotta is offline
I had this problem in my 1990 a while ago. Try putting it into neutral to start it. or try to move the shifter a little bit but keep it inmy column fhifter got out of wack when i had a new ignition in and that happened. If it doesnt start in neutral then I would have it checked by a mechanic
Old 12-08-2009, 01:22 AM
Bearwulf's Avatar
This does sound like key switch & linkage (in column) problem.
97-Lumina LS
Old 12-08-2009, 07:04 AM
Thank you svotta and bearwulf. I will check these out.
Old 12-27-2009, 10:06 AM
Thanks to all for the help. I had 12v getting to the post on the solenoid but not into it. Jiggled the wire and it would start but then turn it off and it wouldn't. I took the wire off, no breaks, and wire brushed everything. It starts every time now.
If it happens again, i suspect it is a bad post at the solenoid.
Rick
Old 12-29-2009, 11:00 PM
Bearwulf's Avatar
Does the inside problem still exist?
97-Lumina LS
Old 12-30-2009, 07:04 AM
No, I don"t know what was the problem there, but after moving the car a little, it was fine. It may just have been in a bind. THANKS AGAIN!!
Rick
Old 12-30-2009, 07:28 PM
It happened again. I was able to get it started by jiggling the hot post on the solenoid. Do I need to remove the starter to replace the solenoid? If so, I might as well replace the complete unit. It is cold here now (unheated garage) so the easiest quickest way would be the best.
Thanks, Rick
