Old 12-04-2009, 04:34 PM
chief153 chief153 is offline
Gear Ratio
I`m getting ready to replace both axle assemblies in my `97 LeSabre. I noticed two ratios are offered for my auto, a 3.06 and a 2.84. I know checking the trans SPID code located on spare tire cover is the fastest and easiest way to determine which axle I have. Is one of these ratios standard and the other an option? Just curious.
Old 12-04-2009, 05:11 PM
happydog500 happydog500 is offline
Re: Gear Ratio
Sorry for not answering your question, just wanted to add one thing I know about it.
One gets 3-4 MPG better then the other.
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 12-04-2009, 09:41 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Gear Ratio
SPID code # F17 (2.84 Ratio) is standard and the 3:05 ratio SPID code F83 was optional with the F-41, or Y56 package.
Old 12-04-2009, 10:07 PM
wafrederick wafrederick is offline
Banned
Re: Gear Ratio
Most parts stores never ask for the gear ratio when getting axles.I know the nearest Carquest and Auto Value parts in my area never do ask what the gear ratio is
Old 12-05-2009, 05:55 PM
Jrs3800 Jrs3800 is offline
Re: Gear Ratio
It would help to know what year the car is..
If the Lesabre is 92-97
F17 2.84 or FW2 3.06
Old 12-05-2009, 07:18 PM
Re: Gear Ratio
Please note my original post, the year is there.
Old 12-05-2009, 07:43 PM
Re: Gear Ratio
My fault for not noticing that...
1997 was the last year for the 4T60-E in a Lesabre..
So you will either have the F17 or the FW2...
are both of your axles bad?
Old 12-05-2009, 08:05 PM
Re: Gear Ratio
Which one is the good gas mileage ratio?
New Balance 662
Trek 8000
Old 12-06-2009, 02:29 PM
Re: Gear Ratio
The F17 2.84 ratio is the one for good mileage...
32-34 on the hwy with a good state of tune can be expected...
Old 12-06-2009, 05:23 PM
Re: Gear Ratio
Yep, 32 MPG is not uncommon at all for me to achieve on the interstate. Jrs, you asked if both my axles were bad, so far they are both silent and the rubber is good, but the car has 180K on the odometer and I just wanted to change them before they went out on me in the middle of nowhere. I drive a thousand miles round trip bi-monthly going to work and I travel through some very unsatifactory territory.
Old 12-06-2009, 07:26 PM
Re: Gear Ratio
Generally the stock GM ones are the best..
I do recommend that you get the best ones you can..
I have almost 184,000 Miles on my 95 Bonneville and do not intend to replace the axles until the rubber goes.. I have no noise either and the rubber is also in good shape... I have replaced both sides on my 95 Van.. Both had the rubber split, one side did it twice.. Both were aftermarket when I got the van.. and didn't last too long.. I wish the factory parts were cheaper..
