Old 12-04-2009, 09:20 AM
Long Con Long Con is offline
Automatic starter for 2000 Grand Prix GT
Hi, I have an automatic starter bought, the ProStart 2-in-1 Remote Starter and Keyless Entry. I was told by one mechanic that he would install it for $130, but the Grand Prix would also need a 'bypass' and 'door locks', which would cost me $90 more.
Is this true, or is he just trying to take advantage of me?
Old 12-04-2009, 09:58 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Automatic starter for 2000 Grand Prix GT
Welcome to AF. Aftermarket remote start units and GM cars with Pass-lock do not play well. The guy is correct, you'll need an add-on module and an extra key installed in it to bypass the Passlock system. Unless you live in an igloo, I'd suggest forgetting about the remote start.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-04-2009, 04:36 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Good one Rich but I think he lives close to igloo conditions up North in Canada so a remote start would be nice and add an engine block heater plus battery blanket.
BTW - I thought the 1999 and up had Passkey III?
Timeslip 08/12/06
AF Community Guidelines
Old 12-05-2009, 09:50 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
I have the transponder type in my car. So does Natalie on her 02 grand Prix SE.
For her birthday a few months back I installed the crimestopper fortress fs-80.
http://www.crimestopper.com/2009/Fortress/FS-80.html
Its installed and works 100%. Only thing is that we didn't use the aftermarket alarm and instead I interfaced it to re-arm the factory one when she locks the doors. Also the interface I went with for the PK3 system was Pats-GM. It basically sits on top of the PK3 transponder and when triggered by the remote start system, it produces a signal like another key. Only thing is, when installing, you have to program it into the cars PCM as though you would another key (turn car on for a minute with working key, ground a wire, then start the car with the remote starter).
Pats-GM
http://ifar.ca/en/products/alpha/pats-gm/
Maybe I'll try and get a youtube video of it in action. Its pretty neat! But definatly a lot of work to install.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
