Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 12-04-2009, 08:24 AM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
95 sohc revs between shifts
so ive had my 95 on the road for a few days and now i noticed when i push the clutch down the rpms climb a little befor they will drop (it takes around 10 seconds for the rpms to drop) i do have a ses light on but the only code is for the egr that has been removed
also this is with the mtx tb on havent swped over yet due to this issue
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 12-05-2009, 10:31 PM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Re: 95 sohc revs between shifts
If your throttle bottle is dirty it might be slightly stuck open.
Vacuum leak can cause rise in rpm.
Idle air control valve dirty.
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
Old 12-06-2009, 03:33 PM
i cleaned everything when it was apart and no vacuum leaks it runs fine at an idle
Old 12-06-2009, 05:45 PM
you could try spraying carb cleaner or brake kleen around your intake gaskets (including block off plate) to see if any of them are leaking.
How high do the rpm rise?
125,000 miles
Old 12-07-2009, 09:42 AM
i did this already vacuum leak was my first thought and it rises around 300 to 500 rpms
i also noticed it does not do it if i just slip it in to neutral and shift with out the clutch (if that makes sense to you sounded funny as typed it ????)
