Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 12-04-2009, 06:29 AM
CKENDZIORA CKENDZIORA is offline
traction control coming on for no reason?
The issue started with the ABS engaging for no reason when the wheels are turned hard lock at low speed? Now this morning the service traction control system light came on? Trans fluid seems to be at the correct level? Any ideas?
Old 12-04-2009, 08:46 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: traction control coming on for no reason?
Any other lights on?
The traction control system relies on the ABS system to operate. The trans fluid would not be a factor in the light coming on. If the check engine light or the ABS light is on than the traction control will be disabled and the light will be on as well.
ABS engaging at low speed is a pretty common symptom for a wheel speed sensor losing signal.
Old 12-04-2009, 08:59 AM
No other lights are on. I may have misspoke the traction control light and the traction control is coming on.... sorry
Old 12-04-2009, 01:42 PM
dewaynep dewaynep is offline
This indicates an issue with an ABS sensor, most likely. Best thing to do is to have it put on a scanner and check the outputs from all 4 wheel speed sensors. There is probably 1 that is weak at low speed (under 10mph).
Old 12-04-2009, 03:51 PM
1999montana's Avatar
1999montana 1999montana is offline
Smile Re: traction control coming on for no reason?
[quote=CKENDZIORA;6073684]...The issue started with the ABS engaging for no reason when the wheels are turned hard lock at low speed? ..../QUOTE]
With the wheels turned to hard lock, the harness to one of the sensors could be creating an 'open' (meaning a break in a wire), or shorting out. Either way, the advise you have received to date is pretty much spot on. You won't know which wheel is causing it until a scan is done.
If I had my way, every GM car I ever owned would be a Chrysler!!!
Old 12-22-2009, 08:16 PM
worm6 worm6 is offline
When my service traction control light came on i found i had one brake light bulb bad. After i fixed bulb my traction light went off. I don't remember abs problem at same time. Good luck
