Old 12-03-2009, 10:06 PM
leylind 1 leylind 1 is offline
2001 s-10 abs light and pulsating
i have a 2001 s-10 2wd that the abs pulsates when not on the brakes also the abs light comes on and speedo goes crazy
Old 12-04-2009, 09:42 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2001 s-10 abs light and pulsating
Welcome to AF on your first post.
It is unusall for the ABS to pulsate when not stepping on brake.
What or how does it pulsate?
Does it brake any wheels?
Speedo going crazy may be a clue to the problem.
You need to get it on a ABS capable scanner and get codes and read out all data and watch all speed sensors fo matching.
Post back any codes.
MT
Old 12-04-2009, 10:50 AM
The abs module seems to engage when slowing head lights flicker and starts pulsating ,and when brakes are applied truck seems to pull left I was thinking wheel sensor but not sure.
Old 12-04-2009, 11:49 AM
MT-2500's Avatar
AF - Advisor
You need to get it on a ABS cpable scanner to check out ABS and speed sensors.
Post back any codes you may have on ABS or other codes.
You may have wiring and or ground problems and battery voltage problems to.
Check battery voltage and charging voltage and grounds to.
Can you feel ABS kick in when slowing with brake pedal off or on?
MT
Old 12-04-2009, 12:40 PM
[quote=MT-2500;6073812]You need to get it on a ABS cpable scanner to check out ABS and speed sensors.
Can you feel ABS kick in when slowing with brake pedal off or on?pedal off
Old 12-04-2009, 12:42 PM
I will get back to you with read out from scanner. THANK YOU FOR THE HELP.
Old 12-04-2009, 01:50 PM
MT-2500's Avatar
AF - Advisor
You are welcome and let us know how it goes.
MT
