Old 12-03-2009, 08:44 PM
niterain niterain is offline
[91 Park Ave] Intermittent Stalling Related to IAT?
Hi,
I've been having some troubles with an intermittent stall. I recently bought a trouble code reader and was able to acquire a code 23. Using my service manual I was able to narrow it down to the Intake Air Temp. Sensor. Problem being is that it was unplugged. Could an uplugged sensor like this be causing an intermittent stall? Essentially my car would just shift into neutral, but i'd still have electricity to my radio etc.
Any help here would be great.
Thanks alot.
Old 12-04-2009, 10:17 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: [91 Park Ave] Intermittent Stalling Related to IAT?
Code 23 IAT will not cause a stall, you have another non-related problem. Check fuel pressure & spark when it stalls. BTW, will it start back up immediately after a stall? If so, be sure to check battery terminals for corrosion & tightness.
Old 12-04-2009, 10:54 PM
Originally Posted by HotZ28 View Post
No, the IAT sensor will not cause a stall, you have another problem. BTW, will it start back up immediately after a stall?
Sometimes it starts up immediately, usually if it doesn't start immediately I can just give it a few minutes and try again. I've never had it stall and then not start.
Old 12-06-2009, 09:13 PM
HotZ28's Avatar
AF Moderator Elite
During the next "few min stall", check fuel pressure & spark.
