Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-03-2009, 04:26 PM
tivles tivles is offline
03 malibu. new radio only works if dash lights on
i recently put in an aftermarket radio into my car...we had to change around some of the wiring in the actual harness attached to the car to align the wires correctly...but the radio only works when the dash lights are on...which means i have to turn on my headlights when i drive. the constant for the power works, meaning i can put in and take out a cd with the dash lights off...but it doesnt play or light up.
i undertand that i can run a wire to the battery to solve this problem, but i was wondering if anyone else had this issue, and was able to solve it with out doing so!
if anyone could help this funny little problem itd be great
car i own: 2003 silver chevy malibu classic
Old 12-03-2009, 06:44 PM
sickcars sickcars is offline
Re: 03 malibu. new radio only works if dash lights on
Find another constant power source, there are a few of them inside under the dash. Look for the big red wire going to the main connector that is usually the ignition wire and a constant power. There is a key on power source there too. This is what I have used in the past and had no problems.
I hope this helps
Old 12-04-2009, 10:06 AM
Scott Dunn Scott Dunn is offline
You have to power wires wrong. There is one power wire that works the lights in your radio - and one for main power. Switch your wires and see.
If you get it right. Turn on your lights and turn your dimmer up and down and you will see that your stereo lights should do the same.
