Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 12-03-2009, 08:23 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Shopping for Ebay exhaust.
I want to get an El Cheapo exhaust for my GST Spyder. I want a full 3 inch. I already have a new Downpipe. The problem is, every exhaust I see necks down at the front. Also, I'm not going to run a cat, but I'm guessing every exhaust I buy is going to leave the space for the cat. So then I started looking at test pipes, and I cant find one of those that isn't small in diameter.
I know some of you guys on here have bought ebay exhausts, so if anyone knows if they offer a full 3" setup that would be awesome.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 12-03-2009, 08:30 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Shopping for Ebay exhaust.
Seems like every 3" cat-back does have the neck. You can cut that weld a larger flange with just a little extenstion. Is the DP an aftermarket? Nearly none of the aftermarket DPs have space for a cat.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 12-03-2009, 10:21 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Here's what I would do. Buy cheap exhaust and cut off the flange. Autozone sells 3" pipe so get one of those and weld it on then put a 3" flange on it. The pipe is bigger at one end so it will slip over the cartback pipe and can easily be welded. Now on mine I did have to cut one of the pipes and twist the pipe some. With the muffler bolted on the cat part was pointed down a little. Dave didn't have any problems with his but I have heard ab others with issues. IMO its still totally worth it for the 110 shipped I paid for it
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-03-2009, 11:42 AM
david-b's Avatar
Dave is THAT guy
What do you mean the cat part faced down? You mean where the cat-back connects to what would be the cat? If so then mine was pointed down too. I loosened everything up, bolted it up to the DP and then had someone hold it in place while I retightened everything back up. Sits perfect in there now.
75 Monte Carlo
Old 12-03-2009, 12:21 PM
Holset powered 420a
Like the part that goes to the front of the car was angled at like 35* to the floor. There was no way a tweaking it would help. The flanges were all loose still.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-03-2009, 12:24 PM
Im guessing you guys run GST catbacks? If so, which one exactly was it so I can buy it.
The DP's I have are both aftermarket. I have an Apex'i N1 dp, and I remember when I bought it, in the description it said that it was a cat-delete dp. But I also have an ebay DP that I will be running from now on (Apex'i cracked) and it is the same length as the APEXi so hopefully if I run it and an ebay catback, there will be no space.
So if you guys could just point me to the one y'all purchased (that is if you like it, and it sounds ok).
Caleb
vanilla gorilla
Old 12-03-2009, 12:54 PM
Holset powered 420a
Yea we got GST catback exhaust. Here is the one I got
http://cgi.ebay.com/ebaymotors/ws/eB...SA%3AUS%3A1123
It did have to be cut and rewelded in one spot so Im not sure I would buy again but if you have a welder than its not really that big of a deal. Most of the hangers worked fine, did have to alter one of 2 of them but thats not a big deal either. It sounds good, real deep and a good bit quieter than my 2.5" exhaust.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-03-2009, 01:48 PM
david-b's Avatar
Dave is THAT guy
Mine was this.
http://cgi.ebay.com/ebaymotors/95-99...item334f6ea0a7
That downward angle is weird. No problems with the above. Hangers all lined up right too. I had to mod the downpipe for hangers but I used the GST downpipe and ran it upside down so it was bound to need work.
75 Monte Carlo
Old 12-03-2009, 02:01 PM
Thanks guys. Now I just have to get some more money up. After buying that weatherstrip.....and my old lady's christmas....I'm about broke.
Caleb
vanilla gorilla
