Old 12-02-2009, 07:24 PM
martinsa martinsa is offline
Check engine lights and traction light
We hitting a bump or turning the wheel hard all the lights come on. Traction light, check engine, anti lock lights all come on at once.
Old 12-04-2009, 10:19 PM
Iflylow's Avatar
Iflylow Iflylow is offline
Re: Check engine lights and traction light
Check the connections and wires from each hub (fronts first). Most likely you have a broken wire from the speed sensor in the hub. The wires are easy to find, they are the only wires coming from your hubs. Pay close attention to anywhere the wires flex or bend with suspension or steering movement.
Also check your brake fluid. Low fluid can cause the ABS/Trac lights to come on.
Old 12-30-2009, 03:22 PM
dwbailey dwbailey is offline
If none of that worked you probably have a bad hub. The lights coming on is a tell tale sign of that issue.
Old 01-09-2010, 05:26 PM
joelee00 joelee00 is offline
could also be the ky ring has too much weight causing keys to move in the cylender. i suggest just putting car key in and seeing if it works
Old 01-13-2010, 09:45 AM
Serpo Serpo is offline
With close to 160k miles on my 2001 Alero, this problem just started when I brought the car to have a bearing replaced.
So the right bearing was replaced and then off I went; it was also snowing then boom 3 light came on:
Anti-lock
Service engine soon
Trac off
Now after I drive for 2-5 minutes, the light comes on but worst, when i turn the steering to the right, i hear this loud humming sound.
I have no clue why it's doing this. But everytime the lights come on, it seems that the rpm of the engine also goes slightly up as if the car has to do more effort to keep the same speed.
Anyone has a clue what this might be? I'm having the brake pads fixed this week. Could it be a bad wire from sensor to hub? Low brake fluid?
Old 01-13-2010, 09:33 PM
Iflylow's Avatar
I would check the wires and brake fluid, but I don't think they are your problem.
If the humming happens only (or louder) during a right turn, I think your left front hub is bad. An ABS capable scan tool can tell you for sure.
