Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-02-2009, 01:01 PM
ve1zp's Avatar
ve1zp ve1zp is offline
Send a message via MSN to ve1zp
427 Truck motor
Would anyone know if any of the car BBC heads will fit the truck motors.Or if anyone knows if someone makes adapters for the intakes or if anyone makes intakes for the T motor..Bruce
Mine is a 1972 in a 1987 suburban
Old 12-05-2009, 07:57 AM
iroc343 iroc343 is offline
Re: 427 Truck motor
Headers will bolt up just fine. They'll be about 3/8" higher up than using a non-truck engine. Shouldn't be a problem as you're most likely fabricating from the collector back anyways. Intake and distributor will be a problem, unless you're using the originals. They make spacer plates so you can adapt a standard intake and they also make distributors for the truck blocks.
Old 12-06-2009, 07:34 AM
ve1zp's Avatar
Re: 427 Truck motor
Thats great do you hapen to know who makes the intakes and distributers ,or the adapters for the intakes , It doesnt have a vacumn advance but its setup for one on the hei Thaught I may try a vacumn advance off a 350
Bruce
Old 12-06-2009, 11:59 AM
ve1zp's Avatar
Re: 427 Truck motor
Im havin fun with this motor haha, they are gonna have a 2 wheel drive truck pull next year at the exibition , thaught I may be able to pull the tow right out of the park ...I wanna keep the torque and maybe a bit of power , its a great old lugger .
Bruce
