Old 12-01-2009, 10:43 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
repair the sliding door ajar issue - very easy
In my Windstar 98, I always get the door ajar light in my dashboard, because the switch in the sliding door is not working, the van "thinks" that the door is not well closed/open.
The annoying part in this, is that all my dome light and interior light was removed, so that the light don't stay lighted when I quit my vehicle and when I drive.
But I found an easy solution to repair it. Instead of disassemble the sliding door and replace the switch, I found a quicker way to do it.
I solder a wire who connect pin 3 and pin 4 (of the door connector end) together. I solder the connector mounted on the car, not the one in the door. The solder should be flat and very solid. Not a solder ball.
Of course, when the sliding door is open/AJAR, it won't detect it, but I don't care.
the pin out of the door connector is:
1: power lock motor +
2: power lock motor -
3: door AJAR switch +
4: door AJAR switch -
This procedure works on Windstar 95-98 only. It doesn't work on 99-03 models, cause their door switch is located on car body.
Now, I can have all my interior light worked.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 12-28-2009, 07:49 AM
oldtobydog oldtobydog is offline
Thumbs up Re: repair the sliding door ajar issue - very easy
Thanks for the tip !
You are so right, this is a very easy method of fixing this problem. I did mine this morning following your method and it worked perfectly.
I had pulled the fuse, but the power windows wont work without it, Bummer !
Now I have everything working again.
Again, many thanks !
Old 12-28-2009, 08:52 AM
Cool. And don't close the sliding door too fast to avoid damaging the solder.
Tags
ajar , door , interior , lights , switch
