Old 12-01-2009, 10:35 PM
automan9482's Avatar
automan9482 automan9482 is offline
Send a message via Yahoo to automan9482
1999 Grand Am GT-"Trac Off" light won't go off
While I'm at it, this same 99 GA GT 3.4 w/AT-OD has the "Trac Off" warning light lit, and it won't go off, whether the ETC is engaged or not. How do I make it go away?
automan9482
Old 12-02-2009, 05:21 PM
INDY86 INDY86 is offline
Re: 199 Grand Am GT-"Trac Off" light won't go off
IMO it's a bad wheel speed sensor or a poor electrical conection. Check the wire for kinks or breaks along it's path. If you have access to an ABS brake scan tool it will help you locate which wheel is causing the code. If you have not ever replaced the front hubs in a car this old I'm inclined to say i'ts one of them, but a rear hub is also a posibility. The sensor is part of the hub.
Old 12-04-2009, 11:11 AM
Thanks, that what I was afraid of. I understand it is a common problem with this kind of car; I just sold an '01 Montana w/ 90K that was in need of front hubs. The ABS light on this GA is also on, so I'll check the wheel sensors.
Thanks!
