Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 12-01-2009, 10:10 PM
gonegoat66 gonegoat66 is offline
Rear window defogger wire
I there a way other than soldering to reattach the rear window defogger wire to the rear window of a 2001 Tahoe? Soldering attempts by dealer have failed twice.
Old 12-02-2009, 12:27 AM
2000CAYukon 2000CAYukon is offline
Re: Rear window defogger wire
I used this product a couple of years ago to fix mine http://www.frostfighter.com/prt2000.htm
This was much better than the Permatex product in the local parts stores.
//2000CAYukon
Old 12-02-2009, 07:58 PM
j cAT j cAT is offline
soldering is on some things very tricky...the dealership is not the place for this type of repair...find a person familiar with soldering electronic componets. or even a skilled plumber ...the use of a soldering flux is applied to the surfaces, then heating the materials with a hot soldering iron until the flux bubbles then apply the solder..have an assistant hold the soldered materials from moving until cool...then with this soldered put some 2 part clear epoxy on the repair to secure the wire joint to window allow to harden..
years ago I have used this silver adhesive as will as the spray material very nice ...very expensive the small can of spray 5OZ was 50.oo....
