Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 12-01-2009, 08:42 PM
susieqgee susieqgee is offline
Won't start battery/starter are good, HELP
My 2000 expedition will not start, the battery is new as of Oct. 09 and I had the starter pulled and tested and it is good. The radio will not come on unless it has sat untouched for a day but once you try to start the car it turns off and will not come back on. I am not sure what to do next. If anyone can help me I would truely appreciate it.
Thank you, Susie
Old 12-01-2009, 09:53 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Won't start battery/starter are good, HELP
Test the battery, sounds like it's probably dead. Did you try jump starting it?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
