Old 12-01-2009, 08:36 PM
Dhenson81 Dhenson81 is offline
2001 Buick Lesabre extended crank time
Hi everyone I have a 2001 lesbare with extended crank time, has no dtc's stored, have replaced map, coolant temp, thermostat. took off egr valve and pintle valve not sticking. It will turn over longer than normal than barely start and than die. Also will die while coasting, also surges every once and awhile. tune up and fuel filter have been replaced. could it be a throttle postion sensor? really stumped here.... Thanks for the help in advance
Old 12-02-2009, 12:06 AM
happydog500 happydog500 is offline
Re: 2001 Buick Lesabre extended crank time
How much fuel pressure? Sounds like a Fuel Pump?
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 12-02-2009, 12:29 AM
vashead2000 vashead2000 is offline
Do a leak down test... Hook up fuel pressure gauge to it. Check the pressure. watch it for about 15 mins or so and if the pressure continuely drops it has a faulty fuel pressure regulator. If thats good to go, whens the last time you changed plugs or wires??
Old 12-05-2009, 10:38 AM
Hey guys thanks for the suggestions. I replaced the TPS and eliminated the extended crank time. Now it occasionaly dies while coasting. I am going to to a leak down test to see if that is the problem.
Tags
problem , starting
