Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-01-2009, 01:51 PM
shirley6don shirley6don is offline
96 olds cutlass heater problem
I had replaced the head gaskets in car and put in new thermostat. I bleed the coolant pipe near the water pump. I must have missed something as I run the car the heat gauge moves up one fourth of the way, but what confuses me is that when I idle the car the heater blows cool air or lukewarm air, and when I push on the gas to make the motor run faster the air turns much warmer (like it should be) and when I let the car just idle again the air turns lukewarm again and even cool.
Any help would be appreciated.
Thanks
Old 12-01-2009, 02:56 PM
inafogg inafogg is offline
Re: 96 olds cutlass heater problem
it sounds like either air or a low level.there should also be a bleeder around thermostat housing.did this start after the head gasket or was it a problem before?
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 12-02-2009, 08:17 AM
I checked out that 2nd bleeder which I was not aware of, and that did the trick. heater works great now. Thanks for your help- much appreciated!!
