Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 11-30-2009, 02:55 PM
mudrunner80 mudrunner80 is offline
Engine options.. please help.
I have a 2000 toyota tacoma SR5 2.7L I want to put the toyota 3.4L into my truck. Can I use the transmission thats in my truck now? its a 5 speed with 4x4. I know the V6 was an option this year. But I don't know if the transmissions are different.
Old 11-30-2009, 10:10 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Engine options.. please help.
The 2.7 4 cyl uses a W59 trans while the 3.4L 6 cyl uses R150F-C .
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 12-01-2009, 12:06 AM
YotaMudder 2000 YotaMudder 2000 is offline
Are the bell housing's different? will this work or would I have to go out and buy a new tranny? or just change my bell housing? I am exploring my options, I want more power. I only have a 3 inch lift with 31-10.5-15 mud tires and I find myself downshifting for all the hills. Any good performance mods I could do?
Old 12-01-2009, 10:17 PM
fasttoyotapu fasttoyotapu is offline
Send a message via AIM to fasttoyotapu Send a message via Yahoo to fasttoyotapu
The answer is obviuosly.... yes. If it won't be the bell housing... the clutch clearance, shaft diameter, the ability the tranny to handle the extra power... Relpace the tranny, it'll save you alot of heart ache.
91 Toyota Pickup - Lowered, Racing Suspension, 96 Toyota Supra 2JZ-GTE Engine w/ 6 speed man. trans. - Crashed racing SCCA - RIP
86 Toyota Pickup - 4x4 - Chevy 305 Engine - Rest stock toyota
Current Project - 90 Toyota Bedless Pick-up - My new mini - Currently Lowering and finding a new bed. The flat bed went to my dad's truck. Merry Christmas Dad!!
Worked:
Doxon Toyota - 4 years
Bowen Scarff Ford and Scarff Ford- .5 years
Old 12-09-2009, 08:05 PM
one more thing... since you have bigger tires on your rig, have you considered putting bigger gears in your rear end? that should solve you issues all around, four banger or not...
Worked:
Old 12-10-2009, 08:11 PM
fourwd1's Avatar
AF -Advisor
Regearing would help, but it's hardly worth spending $800-1000 to regear for 31's. It's barely worth it for 33's.
89 4Runner - stock
Old 12-10-2009, 11:49 PM
Neither is getting a reman engine for about 1000 or 1500 nor a reman trans for 1000 to 1500 bucks. Regearing is easier and cheaper. Unless you have so much spare time to reman them yourself... I work in a shop and i barely have time to work on my own rigs. Its up to you man.
Worked:
Old 12-11-2009, 12:00 AM
Don't forget the engine wiring, sensors, vacuum system, ecu... you'll probably need to get a wrecked truck to do it right. converting a 22r to 22re is tough enough...
Worked:
Old 12-19-2009, 07:36 PM
Kyle4130 Kyle4130 is offline
thats a really good motor you have. i think your getting in way over your head with doing an entire swap. i would just drop some 4.88 gears in your truck. you will totally notice the difference compared to the 4.10s. doing the motor swap is going to require a lot of wiring, new motor mounts, the tranny mounts aren't gunna line up either. your gunna need to re-do your drivelines more than likely. its gunna add up fast. just re-gear your diffs. the 3rz is great.
Old 12-22-2009, 10:52 PM
Thank you...
now on the topic of more power... what engine mods have you done?
Worked:
