Old 11-30-2009, 12:29 PM
Bill Wilky Bill Wilky is offline
1997 2.4L Water pump
My father has a 1997 2.4L Cavalier with 97,000 miles. Where is the water pump located? Is it behind the plate towards the top of the engine on the passenger side? He is getting a small amount of coolant onn the floor. We checked the hoses and they all seem dry.
Old 11-30-2009, 02:21 PM
lake31c lake31c is offline
Re: 1997 2.4L Water pump
it is located on the back of the engine passenger side. u have to take timing chain off to remove pain in butttttt
Old 12-01-2009, 11:29 AM
Thank you
Old 12-01-2009, 05:14 PM
J-Ri's Avatar
J-Ri J-Ri is offline
There is actually a plastic collar with some cotton packed inside that GM came out with to "fix" this problem on the 2.4s... snaps around the weep hole part and lets the coolant gradually evaporate rather than drip. Not a real fix, of course, but they work to keep the floor clean... and it's a whole lot easier than replacing the W/P. The W/P is so close to the exhaust on these that, IMO, the seals never have a chance to not leak.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
