Old 11-30-2009, 11:27 AM
diehard150's Avatar
diehard150 diehard150 is offline
Defrost short 95 f-150
With great appreciation for previous answers I look to the people on this forum for other advice. My 95 F-150 must have another short in it (regarding the heater selection panel). I've all ready replaced the control unit which selects the mode of choice defrost/vent/or floor. And when the defrost is choose the truck hesitates almost like it stutters engine wise(almost like it wants to die really), but when the floor option is chosen theirs nothing wrong (no hesitation or stuttering). So i figure the defrost must have something else connected to it other then the panel control, once this is found out maybe i'll be able to trace the wires and find the short, any ideals?
Old 12-10-2009, 11:38 PM
yukondenali67 yukondenali67 is offline
Re: Defrost short 95 f-150
No idea but my 92 chevy does the same thing
when ac is turned on heater not necessary
florida crackers (ac is a must) post me if you find
a solution thanks in advance
Old 12-10-2009, 11:39 PM
Old 12-11-2009, 10:20 AM
diehard150's Avatar
I've recently had to replace the alternator and recharge the battery, The problem had went away, I'm guessing that the defrost selection draws more power from the battery causing a slight hesitation when driving. And if i ever needed the heat, its now, a whopping 5 degrees out today. Were expecting a heatwave of 31 degrees later. Good luck yukon!
Old 12-12-2009, 09:19 AM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Defrost on most cars engages the A/c Compressor so if the compressor is weak or anything it will make the engine stumble.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 12-14-2009, 09:18 PM
diehard150's Avatar
Thats kinda funny that you mention A/C because theres something sweating during the summer months constantly even when its off, I was thinkin that the selector controls was failing leaving it on. Thats another reason I changed it. What else does a person look for when they think the compressor is failing.
Old 12-15-2009, 12:18 AM
Well, you could have a A/c clutch failing or sticking abnormally, without having an actual compressor failure. I would have someone watch the compressor while you switch it on, see if it is sticking longer than normal. If there's no noise and the compressor isn't locking up, run it normally and keep an eye on it.
'95 Ford F-150
Ford Racing Pride
General Motors who?
