PK3 Key Reprogramming Instructions
ON-BOARD
PROGRAM 1 GENERAL MOTORS* PK3 & “CIRCLE-PL US” originate new master key: 1. P ut the new key into the ignition. Turn it to the ON position. The dashboard security light will flash for 15 minutes. 2. Once the dashboard security light stops flashing, you have five minutes to begin Step 2. Turn the ignition OFF and then back to the ON position. The dashboard security light will flash for 15 additional minutes. 3. Repeat of Step 2. 4. Once the dashboard security light has turned off for the third time, the key will be able to function in the car. It has been programmed into the car’s computer and has replaced ALL previous electronic key codes — the computer will not recognize any other key. add duplicate key: 1. Put the current key into the ignition. 2. Turn the ignition ON and back to OFF. 3. Remove the current key and insert the new key, turning it ON. You MUST do this within 15 seconds. 4. The security light will switch on for two seconds, confirming that the key has been successfully programmed into the vehicle. 4 add duplicate key: (Requires at least one working key): 1) V erify that the new key has “PK3” or “+” stamped on it. 2) Insert the original, already programmed key in the ignition and start the engine. If the engine will not start, see your dealer for service. 3) A fter the engine has started, turn the key to off and remove the key. 4) Insert the key to be programmed and turn it to on within 10 seconds of removing the original key. 5) The security light will turn off once the key has been programmed. It may not be apparent that the security light went on due to how quickly the key is programmed. (If your vehicle does not have a security light (04-07 Grand Prix, Bonneville, Impala), wait 10 minutes 45 seconds to make sure the key has been programmed) 6) Repeat steps 1 through 5 if additional keys are to be programmed. |
Re: PK3 Key Reprogramming Instructions
Welcome to AF. Nicely done, plenty of mis-info on this procedure, did this with my 03 Lesabre.
