Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 11-29-2009, 11:44 PM
CRADWALDNER CRADWALDNER is offline
N/A b16a crx questions
I have a b16a CRX and I am building it all motor. I already have a cold air intake and exhaust so my next step is to buy the intake manifold and throttle body. The throttle body that is available is a 68mm. Im not sure if that is going to lean me out too much or not? Right now the car runs rich almost all the time anyways so im hoping that it will become stoich. After that I plan on dual valve springs, retainers and valves and cams. Are brian crower cams good? What I have read already sounds good but I dont know? What I plan on doing after this is bring it up to 9,000 rpms. Will my setup be good enough to run 9,000?
Old 12-02-2009, 05:41 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: N/A b16a crx questions
An intake manifold and a bigger throttle body aren't going to do much for you, until you get some real modifications. The stock B16A intake manifold is the best one to have for a street driven car, anything else will shift your powerband into higher RPMS. the bigger throttle body won't do anything for you, no real gains or losses from it. Neither modification is going to help you run leaner either. The stock ECU will compensate more fuel (to an extent) when you do mods that increase the air flow into the engine, so trying to add more isn't going to help any. You should do a tune-up, as well as check your O2 sensor if you're really running too lean. Why 9,000 RPMS? Unless you increase your compression ratio and get some pretty aggressive cams, you're not going to be making power up that high. Revving higher doesn't mean you're car is moving faster or that you're making more power, it does however increase stress on engine internals.
Personally I would stay away from Brian Crower stuff, at the very least their valves and valvetrain. I know someone who had their cams, valves, and full valvetrain, who did not have a good experience. One of his BC valves broke clean off, because of a defect. They did give him new valves, valve springs, and retainers, but his head was a total loss. But I've also see threads on Honda-Tech about their cams not being machined enough (or properly), and causing clearance issues; essentially grinding away the cam and parts of the head.
Old 12-02-2009, 09:36 PM
Thank you very much you have been very helpful. What would you do to build a N/A b16a?
