Timing Chain
when should the timing chain be replaced on a 99 sl2
Re: Timing Chain
Never, if the car has been maintained properly. If it's been neglected, it's a crap shoot.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs. 03 GMC Envoy XL SLT 4x4 5.3L V8 |
Re: Timing Chain
i cant say much, but the local saturn dealers (there were 2 of them within a 30 mile radius of me) told me that they should be replaced every 80,000 miles for a DOHC engine. but there again when i replaced mine at 112,000 the tensionor was a little over half way out. if you do decide to pull it out the eastiest way to get at it would be to pull the motor. just my opinion. i had to put a rear main oil seal in mine shortly after i picked it up. hence me pulling the motor.
Re: Timing Chain
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
