Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-29-2009, 04:37 PM
slightytilted98 slightytilted98 is offline
2001 Impala temp gauge
I have a problem with my 2001 Impala. When the car is running, the temperature gauge doesn't register at all. After the car is shut off, it sounds like something is still running. I can't really afford to take it to a mechanic and am going to have a mechanic friend fix it if we can figure out what's wrong. He thinks it sounds like the therm. sensor. Please help!! Thanks!!
Old 11-29-2009, 07:55 PM
j cAT j cAT is offline
Re: 2001 Impala temp gauge
if you have no coolant in the system/no flow the temp guage will not work..
what is the coolant used ? dexcool ? is the radiator full ? did you check the thermostat for being stuck open ? does the heat work ?
Old 11-30-2009, 10:24 PM
bozr's Avatar
bozr bozr is offline
Check the connector on the coolant temperature sensor. If it's disconnected the cooling fans will automatically turn on.
I love the smell of Stoichiometric in the morning.
