Go Back   Automotive Forums Car Chat > Mitsubishi > Lancer
Old 11-28-2009, 05:09 PM
yellow_evo yellow_evo is offline
blown head gasket or blown turbo?
Hello,
Just recently I notice excessive amount of smoke was blown from my exhaust pipe, I just flush and refill both the engine oil and coolant fluid .
The coolant tank was empty and the engine oil was spoiled and run low
after a 60 minute drive.
My first conclusion was that of a blown head gasket , and so I run out
and bought a compression tester to see if that were true.
I check and crank the car 2 times on each cylinder,no matter how many
times I crank or how long the cranking time is ,it still come up with the same number.
Here are the results.
cyl # 1 : 180
cyl # 2 : 180
cyl # 3 : 182
cyl # 4 : 182
So can anyone here tell me is it my head gasket thats blown or the turbo?.
Old 11-30-2009, 06:51 PM
rhandwor rhandwor is offline
Re: blown head gasket or blown turbo?
Napa sells a test kit to check for combustion gas in the anti freeze. I normally use a radiator pressure tester and check with the engine running. Put appx. 12 psi on the gage and if it pulses it indicates a blown gasket.
Auto Zone and Advanced have a tool rental program.
At the speed a turbo runs a bearing should be bad with anti freeze in it.
Old 11-30-2009, 08:53 PM
Thanks, I'll try that.
Today went to the dealer to have it diagnose the problem
They unable to find the symptom.
Old 11-30-2009, 09:00 PM
Scrapper Scrapper is offline
AF Premium User
i'll say it's the turbo..
Old 11-30-2009, 09:15 PM
They checked the intercooler pipe
And no trace of oil or coolant got in.
Old 12-10-2009, 01:17 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
What color is the smoke?
Kris
2012 Genesis Coupe 2.0t
Old 12-19-2009, 07:19 AM
I checked the oil cap and saw some milky white fluid on the cap along with engine oil.
I'm pretty sure the head gasket is blown or crack.
Even with a good compression reading is not really telling me anything.
Old 12-19-2009, 07:38 AM
http://www.rxauto.com/demo.htm
I never used the head gasket product but they sell a test kit for checking for combustible gas in the antifreeze. The video shows how to use the tester.
Old 12-19-2009, 07:01 PM
RahX RahX is offline
Some white/yellow/tan buildup under the oil cap does not tell you anything, it is the most likely spot for moisture to build up, I see it quite often. If your oil is milky that is a different matter. I'm pretty sure the turbo is oil cooled and the intercooler is air/air so if you are blowing white almond smelling smoke, your headgasket is probably leaking or you have a crack. Pull the plugs and see if any are spotless. They should have some sort of buildup, white/tan which is completely normal. If your engine is burning coolant, you will have a plug that is steam cleaned to perfection, no buildup and it might even have a greenish tint to it. Your compression readings are about as perfect as you are going to get.
Old 12-21-2009, 12:40 PM
I might want to add that the car warm up faster than normal but will not overheat.Sometime smoke will rise from the exhaust manifold.
no coolant or oil been lost after a 60 minute round trip, though white smoke
continued to be seen.
yet the car feel so sluggis.
Old 12-21-2009, 12:53 PM
A cracked manifold would lend itself to the spool issues and the smoking manifold, but you say there is white smoke? Hold your hand behind the exhaust while the car is on...smell it. What does it smell like?
Kris
