Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-28-2009, 03:43 PM
Cajunbrewer Cajunbrewer is offline
92 Camry V6 probs
Ok guys I am at a standstill with this car....My previous motor froze up replaced motor with another stock motor..Now I have fire and fuel but the injectors are not opening...Fooling around today I put a remote start switch on the starter and the car started and ran for bout 10 minutes I shut it down cause I did not put antifreeze in yet...So I put in the rest of the fluids that it needed and tried with the starter hooked up the way it should be and nothing the starter spun and it would not start..Then I tried the remote and starter spins but would not fire up again very confused and frustrated any help would be appreciated many thanks in advance..
Cajunbrewer
Old 12-03-2009, 10:00 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 92 Camry V6 probs
My guesses would be the the ignition switch and/or the main AM2 fuse. Also check if you have power to the fuel pump and the coil packs. Finally check the igniter. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 12-04-2009, 04:02 PM
csaxon csaxon is offline
Are you saying that the starter spins but the engine does not crank or that the starter spins and the engine cranks but will not start?
It worked fine until I fixed it!
