Old 11-28-2009, 11:52 AM
Macio4ever's Avatar
Macio4ever Macio4ever is offline
Strange effect and problem with 2K clear
Hi,
Experimenting with clear 2K I got strange effect which in fact is a problem with finish of my FW10.
I used Dupont Duxone and used Hiroboy's guidelines for painting. When wet coat was on the body everything looked fine. Looked like glass.
After about 15 minutes some very, very little holes/dimples have appeared. They look like someone made them using needle and delicately puncture surface.
If you look at the model from 15-20cm you can notice them only with strong light source.
Proportions of lacquer and hardener were measured precisely. I have added 10% thinner (Finishers Pure Thinner)
Body has been wet sanded and washed before painting. Fully dry, 24 hours in drybooth.
Any ideas?
Macio4ever
www.mgsf.pl
Old 11-28-2009, 01:49 PM
stevenoble's Avatar
Re: Strange effect and problem with 2K clear
Had a similar result myself when using the Finishers thinner with 2K. Now I use the base coat thinner exclusively with the 2K and so far everything has been fine. So it could be the thinner. Have you used it before with the 2K or is this your first try with it..??
Steve Noble
Old 11-28-2009, 03:38 PM
Macio4ever's Avatar
First try with Finisher's. Previously I used Tamiya Lacqeur Thinner and it was fine.
Stupid, stupid, stupid I should stick to Tamiya I have already tried.
Macio4ever
www.mgsf.pl
Old 11-28-2009, 03:52 PM
stevenoble's Avatar
I cured mine by lightly flatting out the offending holes until they were almost gone and then used Tamiya and Finishers compounds to restore the gloss...
Steve Noble
Old 11-28-2009, 04:18 PM
Macio4ever's Avatar
I am considering to lightly sand whole body then lay down one more wet coat of 2K.
Anyway - thank you for help!
Macio4ever
www.mgsf.pl
Old 11-28-2009, 06:35 PM
SkylineFan's Avatar
SkylineFan SkylineFan is offline
Those little dimples are called "fisheyes" and they are caused by Moisture, any kind of contamination on the surface of the model, or in the airbrush gun or air entering the gun. It is also caused when you apply the first coat too heavy and solvent popping occurs making those dimples. You will need to reclear and hope it does not occur again... Next time it happens... Keep clearing the car as normal.. Then take the jar you have hooked to the airbrush and dip a clean brush in the clear and Dab the fisheyes to fill them in. Then reclear on the next coat. The new coat of clear will melt the now raised dimples level. Even if they dont you can knock them down with sanding and polishing later.. its an effective way to save a 2K paintjob because once you clear the car with 2K there is no starting over..... 2K clear does not strip!!
DaveT
Old 11-29-2009, 03:50 AM
Macio4ever's Avatar
Thanks for the ideas! Still, I tend to belive that it is thinner issue. Why? Because I don't know how could I have much, much less contaminated environment. I have oilless compressor, 2 moisture filters inline, single use paint containers, drybooth and usually not hurry painting after washing model.
Anyway, one again - thanks for your help.
Macio4ever
www.mgsf.pl
Old 11-29-2009, 05:01 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Mmmm, I not agree at 100% with Steve: fisheyes are caused by the thinner that try to evaporate. You'll get sure fisheyes (we call them "crater") by moisture or contamination, but you get immediatly, simply the clear can't stick properly on the surface in some points: typically you get them on resin parts poorly cleaned (and sometimes also on parts perfectly prepped, we're speaking of sylicon contaminations).
If you get craters after some time, after achieved a perfect surface the trouble would be the thinner: you must try to use a bit less thinner and build thin layers. BTW all you need is sand down a bit the part and re-coat.
PS Edit: with my crappy English whe I write "I not agree at 100%" I mean "I not fully agree" in the opposite sense of "I don't agree, fully" , fiuuwwwww...
gio
Old 11-29-2009, 07:26 AM
klutz_100's Avatar
Originally Posted by gionc View Post
when I write "I not agree at 100%" I mean "I not fully agree" in the opposite sense of "I don't agree, fully" , fiuuwwwww...
I see.....
Old 11-29-2009, 08:46 AM
Macio4ever's Avatar
Happily I've catched the right meaning
Macio4ever
www.mgsf.pl
Old 11-29-2009, 09:36 PM
Didymus Didymus is offline
My auto paint supplier recommends UR40 Medium Temp Reducer instead of lacquer thinner. I tried using regular lacquer thinner with base coats until I got a batch that curdled. Since then I've stuck with the Reducer and had no problems. I think the same would apply to any urethane, including 2K clear.
Old 11-30-2009, 01:32 AM
Macio4ever's Avatar
Next time I will use DuPont reducer and will see. This 2K could be sprayed without reducer but it seems a bit to thick to me and my 0.5mm airbrush.
Macio4ever
www.mgsf.pl
Old 11-30-2009, 02:30 AM
matador88's Avatar
matador88 matador88 is offline
i am dealing with the same issue now. it looks like more thinner is better than less because you can lay down thinner layer of clearcoat and thinner can evaporate better. with less thinner i need thicker layer to achieve uniform gloss - it is flowing/leveling better (thinner is orange peeled).
i untderstand that with 0.3 nozzle you have to have much thinned stuff than recommended so thinner needs to evaporate more and thick layer is not good for it.
hm...
Old 11-30-2009, 02:41 AM
kaho's Avatar
kaho kaho is offline
There are thinners for 2K clears?
Old 11-30-2009, 08:26 AM
klutz_100's Avatar
If you find a good source for good auto thinners in Warsaw, please let me know where it is!
