Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 11-27-2009, 11:08 PM
msca msca is offline
lowering a 2005 cavalier
does any one no what the cheapest and easyest way to lowering a 2005 cavalier.i just painted the car and i think it would look better if it was lowered a little.and how bad would it make it ride.thanks
Old 12-02-2009, 01:14 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: lowering a 2005 cavalier
Cheapest and easiest... just cut a bit of the springs out.
Do it right, which is not cheap, but will cause fewer problems. Install lowering springs and have it aligned. Special parts may be required to be able to get the camber correct after lowering it. A drop of 1.4" gives the best handling (control arms parallel to ground).
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
