Old 11-27-2009, 10:06 PM
andy_99w_csh andy_99w_csh is offline
Exclamation Help!!!92 k1500 swap
I have a 92 1500 manuel trans. 4x4 wit a 350. It is lifted and i do not have alot of power,i want to swap to a 454 and i want to go to an automatic trans. I was thinking of a 454 with a edelbrock carb and intake steup with a turbo 350 or 400 tranny i want to know if a 454 will bolt right up to the mounts? And i dont care about emissions.will the exhaust manifolds bolt up to the 454 and on the tranny what kind of wiring or vaccuum lines do i have to run if any? Will a 350 or 400 tranny bolt up to all the 4x4 parts and do i have to change my radiatorand fan? Or anything you can think of?
Thanks for the help
andy
Old 11-28-2009, 08:42 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Help!!!92 k1500 swap
Thanks for the help
andy
Your local bone yard has interchange books with a lot of that information in them.
MT
Old 11-28-2009, 01:30 PM
I no that a 454 will fit on my mounts so i need to no on a 92 k1500 trany is there any wireing i have to do. On a 92 k2500 it has a 700r4 trany so can i swap to that trany and what about the dive shafts what do you guys think
thanks
andy
Old 11-28-2009, 05:22 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
What trans do you have? (t5?) It might be hard to put in a 700r4 in the place of a manual. At the very least you will probably need a donor wiring harness, ECM(what little it was in 92), and maybe even have to switch over the transfir case. I am not sure though. Have you tried Google? I'd be willing to bet others have completed this swap in the past.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-28-2009, 05:50 PM
it a 5 speed maybe a t5 or do you know any trans that would work for this swap thanks
Old 11-28-2009, 06:58 PM
ok i have been doing some research and it doesnt look like i can change the tranny but do you guys know if i took an tranny transfer case and driveshaft out of a k2500 would that work and what year did the trannys have the vaccumm lines and the kickdown cable so i wouldnt need a computer?
Thanks
andy
