Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-27-2009, 09:57 PM
69chev 69chev is offline
1997 chev tahoe blowing transfer case fuse
Gonna starts snowing soon HELP
Hey there new to the forum. So when starting vehicle 4 wheel drive switch lights up for a quick second. I have tried to remove fuse and wait ten minutes. i then replaced fuse. Then turn ignition off and on 5 times per some other postings. It still blows transfer case fuse. Any help is much appreciated. Thanks in advance
Old 11-28-2009, 11:08 AM
777stickman 777stickman is offline
Re: 1997 chev tahoe blowing transfer case fuse
Welcome to AF.
List the selections on your t-case switch.
Also describe exactly when the fuse blows.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 11-28-2009, 01:27 PM
Originally Posted by 777stickman View Post
Welcome to AF.
Assuming you mean selections on dash for 4 wheel drive...? They are 2 hi 4 hi and 4 lo. After replacing fuse it blows as soon as I try to engage 4 wheel drive to 4hi. Thx for replying 777.
Old 11-28-2009, 06:19 PM
With that info I would suspect an internal short in the encoder-motor at the t-case.
You could remove the electrical connectors (2) at the encoder-motor and try it, but I'm not sure if the selector switch lights will work?? Might be worth a try. If the lights still work and the fuse doesn't blow then lean towards the encoder-motor being faulty. The motors are prone to internal electrical failures.
Other items in the system that could cause the fuse to blow are the selector switch, t-case control module and wiring.
Really need to get it properly diagnosed before throwing parts at it.
57 Chevy 210
Old 11-28-2009, 06:24 PM
j cAT j cAT is offline
it could be the encoder transfercase motor . also the wires going to this motor could be damaged...these wires have been known to get chaffed and shorted out to engine /frame metals..follow these wires back...with battery removed you could also check for a short to ground..
