Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-27-2009, 06:12 PM
zeakieb1 zeakieb1 is offline
93 camry driving me nuts
have a 93 camry 2.2 no fire checked ing. coil seems to be good also replaced ignitor and checked pickup coil check engine light stays on when the key is on position (not running). please can someone shed some light new dist cap and wires could it be the computer or the ignition coil ? tried to disconnect battery to reset ecm no such luck.
Old 11-27-2009, 07:11 PM
JennyDee JennyDee is offline
Re: 93 camry driving me nuts
Lets review a few items.
Did you replace the rotor?
Did you see the rotor moving when you cranked the engine? Note, this would tell you that the timingbelt is moving... but the timing could be off.
How did you check the coil?
Old 11-28-2009, 05:32 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
Did you remove the coil from the distributor and actually inspect it for cracks? The coil can develope hairline cracks and short itself to ground on any metal inside the distributor, causing a no spark condition. This is a common problem on the first 3 generations of Camrys as they rack up lot's of miles and the coil ages.
Mike
Old 11-30-2009, 10:46 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Contrary to the manual's specifications, a coil that checks out barely within the primary and secondary resistance specs may actually be bad. As mentioned, cracks or ripples in the body or the epoxy filler mean an internally shorted coil.
The OEM coils give a good lifespan of 150k miles or so....not so for aftermarket replacements which eke out only 30k or so miles, with a very small or no warranty to boot (even a one year warranty is useless unless you drive 30k miles in a year...not likely).
Coincidentally, my third AM coil crapped out last week...only 23k miles old. Fed up, I ordered an OEM one. Cost was double but I expect about 6 times the lifespan, and fewer roadside meetings with the tow truck. Also ordered the oil seal kit for the distributor to kill two birds with one stone. [EDIT] Here is the thread link to my distributor oil seal replacement:
http://www.automotiveforums.com/vbul...d.php?t=937638
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Last edited by jdmccright; 12-03-2009 at 09:32 AM. Reason: Added link to another thread
Old 12-02-2009, 10:16 AM
JOET/CAMRY JOET/CAMRY is offline
Please post back the results. If possible, with some pics of the distributer seal overhaul. Thanks.
JOET/CAMRY
