Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 11-27-2009, 03:40 AM
MitchP MitchP is offline
'95 T-Bird 4.6 V8
I have a '95 Ford Thunderbird LX 4.6L V8 that has been acting up lately. The problem is that when I accelerate normally the car tends to hang or stutter right after dropping into fourth gear. But if I take my foot off the pedal for a second and then accelerate again everything seems to be fine. Around May of this year, my car started doing this and everyone I talked to thought it was the fuel pump gone bad. So I took it in to a mechanic and had the pump replaced and everything seemed to be fine up until around July when it started in again. I've tried the gas treatment bottles, replaced my fuel filter but the problem remains. Not sure if I should just fork out the cash to have it tuned up and hope that solves it or get some more opinions. Just hoping that this is not going to cost an arm or a leg. Any ideas? Thanks
Old 12-08-2009, 05:12 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: '95 T-Bird 4.6 V8
Welcome to the forum MitchP. You should be able to get the codes read at Autozone or other places like them. If the car hasn't had a tuneup in a while it's money well spent. At least check the condition of the spark plugs.
The Original 97Bird
Old 12-08-2009, 06:57 PM
Thanks for the reply 97Bird. I have the next couple days off, going to take it into Autozone and see what shows up. Thanks for the advice.
Old 01-05-2010, 03:01 PM
five-oh-H.O. five-oh-H.O. is offline
could it be torque converter shutter?
Old 01-05-2010, 03:34 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Check the EGR valve and DPFE sensor. I had the same problem with my 4.6L and is common on the 4.6Ls. Remove the DPFE sensor, smack it in your hand a few times to get the water out, and reinstall, ensuring the hoses are tight and the electrical sensor plugged back in. It should be mounted on the back of the passenger side cylinder head.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
