Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-26-2009, 06:02 PM
Jdeguz Jdeguz is offline
engine smells like gas
Basically when ever I drive the rodeo the engine smells like gas. I can't find any leaks but the fumes are real strong. Does anyone know where I should be looking. I know its coming from the engine and not the gas tank. Thanks
2001 v6 rodeo 100k
Old 12-04-2009, 10:23 AM
brokenrinker brokenrinker is offline
Re: engine smells like gas
Pull the vacuum hose off the fuel pressure regulator and see if there's fuel in it. When the diaphragm on the regulator fails it leaks fuel into the vacuum line.
Old 12-04-2009, 10:31 AM
jd-autotech jd-autotech is offline
if there is a leak your service engine soon light should be on if so check codes and you may have to have it checked with a smoke machine
