Old 11-26-2009, 04:30 PM
koolz68 koolz68 is offline
power steering
I can hear my power steering whine when i turn my wheel. The power steering fuel pump is full. Whats wrong? Thanks
Old 12-01-2009, 09:25 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: power steering
Could be contaminated fluid. Start with having the system flushed. Most of the P/S flushes I've done fix the whine. Probably 95% or better. If it still makes noise, the pump is bad. Start with the flush, because it will need to be flushed after the pump is replaced to remove any metal from the system.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
