Old 11-25-2009, 06:56 PM
brinkz brinkz is offline
roaring noise
Ok here it goes, need the pros for this one. 89 civic dx, 1.5l, auto. I have been having a roar noise coming from the front end of the car since i got it. It gets louder and faster as the car speeds up. I shut the car off while coasting and the noise was still there. Drive or neutral dosent matter. The only time the noise goes away is when i do a hard right turn. There is no other noises, no pops or clicks, anything like that, and i cant seem to see anything that might be rubbing together. Any thoughts where to look would be great. Oh yeah i tried driving fast in reverse tonight, and the noise is not there.
Old 11-26-2009, 07:45 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: roaring noise
Its a wheel bearing, I believe its your Left side too if it goes away when you turn right. Should put a lot more pressure on it then and tighten everything up, making the noise go away.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 11-26-2009, 08:46 AM
Re: roaring noise
ok i will give that a try, I have a new bearing so it's just a matter of getting it pressed into the spindle.
Old 11-26-2009, 06:37 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
Re: roaring noise
if its a wheel bearing the noise will not go away when more pressure is applied to it, it should get louder.... thats just silly more pressure making it tighten up..... if that was the case just re tourque your axel nut and it would go away
Current cars
1990 honda civic dx High Comp mini me
1986 HONDA CRX SI
Need a winter mobile....
Old 11-26-2009, 11:06 PM
Tony's Avatar
TLD Member #1
Re: roaring noise
How do you think it makes noise? From loose bearings. Its definitely a wheel bearing considering its a "roaring" noise that happens at all times.
When the pressure is applied to it, it takes up the free space between the bearings and the races that wasn't there when the bearing was new, but is now from it being worn. When the races apply the pressure they were intended to apply on the bearings, everything becomes nice and quiet since that is the way they were designed. Thats my take on it...haven't been through that class yet and I could just be talking out my ass here.
Tony
Old 12-22-2009, 04:26 PM
DownToGround DownToGround is offline
Re: roaring noise
tony, tony.. i believe it is the backing plate/shroud rubbing against the back side of rotor.. had it happen a million times. makes a horrible noise.. try that.
Old 12-23-2009, 12:45 PM
Tony's Avatar
TLD Member #1
Re: roaring noise
I don't consider that a "roaring" noise, thats just a damn annoyance, lol
I know exactly what your talking about and have had it happen to me a lot too, I hate those things.
Tony
Old 12-29-2009, 04:35 PM
Re: roaring noise
well i know it's not the brake shroud for sure, cause it aint there no more. still havent had a chance to change the bearing yet though, no time to do it yet.
Old 12-29-2009, 07:05 PM
Re: roaring noise
with your car either on the ground or in the air shake the wheel feeling for play..
