Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-25-2009, 02:31 PM
Bob Mayo Bob Mayo is offline
1999 SC2 Shifting problem
This car has an automatic tranny. When the tranny shifts from 2nd to 3rd at 2800 RPM's there seems to be an extra shift a second later. If I count the shifts from standstill there are 4. That would make it a 5-speed and I don't think it is.
Also I noticed that when coming to a stop, the idle is too high. Once the car stops fully the idle drops to normal. I drove the car at 35 MPH and shifted into neutral. The RPM's are at 1500. If I keep rolling the RPM's stay at 1500 but as soon as I fully stop they drop to around 900.
The engine was replaced a couple months ago and I do not know if it could be a linkage adjustment. Since I do not drive this car much I do not know if these problems existed before the engine swap. Thanks.
Old 11-25-2009, 04:56 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: 1999 SC2 Shifting problem
Perhaps you are also noticing the torque converter lock-up after it shifts into 4th gear?
This is normal. The PCM is programmed to keep the engine idling higher when coasting. The same thing happens with cars with manual transmissions when you push in the clutch or put it in neutral and coast to a stop. This is supposed to decrease emissions from unburned fuel.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 11-25-2009, 06:02 PM
Thanks for the reply. Can you describe what Torque converter lock-up feels like?
When you say that this is normal do you mean for this car? My Villager does not do this. It seems dangerous to have the idle at 1500 RPM's when you are trying to stop the car.
Old 11-26-2009, 12:50 AM
Ruley73's Avatar
Normal for Saturns (S-series), but most other cars behave the same way. I understand your point about it being dangerous, but keep in mind that when you hit the brakes your engine RPM drops because the brake booster pulls a modest amount of vacuum from the engine (which is yet another reason the engine RPM needs to be above idle when coasting). Also, when the car is in neutral the higher engine RPM doesn't hinder the car's stopping ability because no power is being transferred to the driveaxles.
My rides:
- Steve Smith (Red)
Old 11-26-2009, 12:35 PM
Thanks for your response. I tried coasting in neutral just to see the RPM's without the transmission engaged. I'm going to try a fluid and filter change to see it it helps the shifting problem.
Old 11-27-2009, 02:29 PM
RC1488 RC1488 is offline
Replace your ECTS and Clean your throttle body along with the fluid/filter change
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
