Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-25-2009, 11:23 AM
shmedly shmedly is offline
no start
have a 90 olds ciera with a 3.3 engine, it ran good at the beginning of summer and i parked it, now nov i put a new battery in it and it almost starts alomost like the timing is outta wack? but it just wont run.
so far it has new battery, new fuel filter, air filter, oil and filter, gas.
i did notice a ses code so i did the paper clip trick and it says 42?
Old 11-25-2009, 12:21 PM
maxwedge maxwedge is offline
A990 racer
Re: no start
42 is usually caused by a bad ign module, or connections to it. I assume you have good fuel pressure, what does the spark look like, jump a good sized gap and blue?
Old 12-01-2009, 02:58 PM
Re: no start
ok sorry bout the delay.
changed the coil pack and module. still no start.
yes have fairly blue spark.
fuel pressure yes it sprays out when i pushed in the shrader valve.
the ses is not on now prolly cause of unpluggin the battery.
the car when tryin to start it turns over very fast, but doesnt even try to start. but when i let off it kinda backfired out the exhaust?
what do i do kknow
Old 12-01-2009, 07:32 PM
A990 racer
Re: no start
Not good make sure you have good compression, don't just keep replacng parts also.
Old 12-02-2009, 03:47 PM
Re: no start
comprression is good 145 150 cold engine.
injs pulsing according to test light
have voltage at inj harness
have 20 psi key on 42 while tryin to start.
i did notice that the temp gauge seems to be stuck way beyond the high reading if it has anything to do with it.
maybe crank sensor?
Old 12-02-2009, 06:35 PM
A990 racer
Re: no start
20 psi? It should be 37 at least, spray carb cleaner into the intake see if it fires.
Old 12-02-2009, 07:30 PM
Re: no start
ya i just went out and tried using quick start made no difference at all.
Old 12-03-2009, 08:00 AM
A990 racer
Re: no start
Then your spark is non existent or too weak.
Old 12-04-2009, 07:00 PM
Re: no start
ok been messsin with this thing again.
pulled out plugs they were soaked.
oil was overfull of gas oil mix.
and had a temp sensor code ?
ok changed oil, dried plugs off, changed sensor.
it fired but wont keep runnig and was popping like crazy.
then stalled
ok tried again and nothing..
pulled plugs and they were dripping with fuel.
any ideas which way to go with this wreck?
Old 12-05-2009, 10:31 AM
A990 racer
Re: no start
Something is making the engine run too rich, leaking injectors, excess fuel pressure, leaking fuel press reg., bad map sensor.
Old 12-05-2009, 12:21 PM
aleekat aleekat is offline
Re: no start
If you have a timing light, check it. Timing could be way out of whack...
Old 12-06-2009, 09:44 AM
A990 racer
Re: no start
There is no way to set or adjust the timing on these cars.
Old 01-01-2010, 11:06 AM
Re: no start
update!!!!
ok been awhile
replaced fuel pump and filter press now at 45 instead of 20.
still same prob..
ok so tried a new ecm..
still nothing..
same problem
so was told to try putting some denatured alcohol in the tank guess that removes water etc.
ok so dumped in a full can about 4litres to a 1/4 tank of fuel primed it thru fuel rail and tried it again...
it fired stumbled and died but restarted after a few minutes it was running.
long story short try adding alcohol before anything else.
