Go Back   Automotive Forums Car Chat > Land Rover > Discovery | LR3 | LR4
Old 11-25-2009, 11:41 AM
mike7051 mike7051 is offline
00 disco leaking timing cover
ive got a 2000 discovery that has coolant leaking out of the top of timing cover. anybody ever done a timing cover on one of these its a 4.0 doesnt look too bad. to diagnose it ive already had it down to the cover with no problems. thanks everyone
Old 10-18-2010, 03:44 PM
boarder_punk's Avatar
boarder_punk boarder_punk is offline
Send a message via MSN to boarder_punk
Re: 00 disco leaking timing cover
I've done a bunch. Pretty simple, but have to remove the oil pan for access to the oil sump where it bolts into the bottom of the front cover, or you will crack the cover trying to remove it. Other than that the biggest pain is lining up the oil pump drive gear with the woodruff key on the crankshaft when you're putting it back together. Do the timing chain while you're in there too.
Old 12-26-2011, 07:30 PM
Affordable Engine Affordable Engine is offline
I have a company that sells used engines called affordableengine.com and we recently sold a rebuilt '03 Discovery engine to a guy in CA. The rebuilder told me some great info about timing chain covers that may help you out. He said when installing a used engine make sure you get the newly designed timing cover chain. I think he said in 2003 or 2004 they changed the design to make them fit better.
So, if you are changing the timing cover, make sure you get the updated one.
