Old 11-25-2009, 10:39 AM
xpeed's Avatar
xpeed xpeed is offline
Aoshima Mitsubishi Lancer Evolution X GSR
Finally finished this build. Even though I was the first to get it on here, I ended up not finishing it first but I think the slow progress paid off for me with this build. There are some minor flaws but overall, I'm impressed in how well this came out. I've noticed that the last two builds from members here didn't paint the headlights with the black housing, so I've done that with mine. You can see the progress work here. http://www.automotiveforums.com/vbul...d.php?t=961123
What do you guys think?
Lexus LF-A Roadster Concept with my bodykit design
"Current Projects"
Nismo Kure GT-R - 0% Sileighty/Onevia - 35%/25%, MCR R34 GT-R - 10%, R34 JGTC Xanavi - 30%, JGTC Raybrig NSX - 0%, 2009/2011 WRX STi - 50%/0%, D1GP Kazama S15 - 55%, Toyota Celica - 2%, Calsonic Z Super GT - 0%, Calsonic R32 GT-R Race car - 5%, C-West RX-7 - 40%, Nismo 350Z 5%, Blitz Chaser - 90%.... a lot of unfinished work.
Old 11-25-2009, 12:14 PM
koksik's Avatar
koksik koksik is offline
Re: Aoshima Mitsubishi Lancer Evolution X GSR
Good job, I like wheels and blue wheel nuts. Only this paint. Some place's have more metallic flake's. And every panel corner is more bright. Try make some panel lines with black paint. Will be looks much better
Old 11-25-2009, 01:04 PM
Simas17's Avatar
Simas17 Simas17 is offline
great job
Old 11-25-2009, 05:18 PM
Twowheelsrule Twowheelsrule is offline
Nice looking car and the blue highlights on the parts are nice too!
Mark
Old 11-27-2009, 03:15 AM
kaho's Avatar
kaho kaho is offline
The stance looks perfect! Did you lower this or did that come box stock? I like the blue it looks so deep at some parts, but the panel edges look like there's not enough paint (or maybe it's the reflections) Like mentioned try doing a black wash on those edges.
Old 11-27-2009, 06:44 AM
drunken monkey's Avatar
Razor Sharp Twit
Agree on the paint; it isn't as even as it could be but metallics out of a can are very hard to get right, especially around panel edges.
If you can, you should spray a few mists along the panel lines, sand down smooth then cover the body.
Don't try to get complete coverage in one go with a spray can.
It's very tempting to go heavy with a single coat straight away because it looks ok as you're doing it but as it cures, it will pull away from the edges.
Also, where you joined the rear bumper to the body.
It might've been better to use some secondary support inside the parts; a piece of laid styrene across both parts maybe. That way, you could clean up that glue joint and re-mark the panel line.
As others have said, fill in the panel lines.
Maybe mix up a dark, dark, dark blue (avoid black).
Don't forget to paint inside the exhaust tips.
AF's Guidelines
Read them.
Old 11-27-2009, 08:49 PM
xpeed's Avatar
Kaho - It came box stock. There are options if you want it lower or not. I chose the lower with bigger wheels. That's why the stance looks aggressive.
As for the panel lines. Some are because of the reflection from the sun, but yes, some panel lines I've noticed don't have enough paint so I will try to take up drunkenmonkey's tip and try to fill it in with some dark blue paint. As for the exhaust, I've already filled it in black. Thanks for the comment.s =D
"Current Projects"
