Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-24-2009, 09:35 PM
donmaton86 donmaton86 is offline
Exclamation smoking black 99 gst w 6bolt
the car is smoking black like hell i dont know whats gng on some have any idea whats gng on..hesitates in the biginning of throttle then revs fast past 3000rpm's...
Old 11-24-2009, 09:53 PM
99 gst
smoking alot of black 6 bolt ina 2gen any ideas..
Old 11-24-2009, 10:03 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 99 gst
Welcome to AF.
Let me start off by asking to please post the questions in the right forums. Secondly, there is no need to post the same question in other threads and make multiple threads on the same topic. Lastly, we need more information in order to help you. Please be more descriptive. Thanks
For the problem, there's really no way to give an answer from this little information. How many miles? What kind of upgrades? Has regular maintenance been done? Is it smoking at idle or full throttle? The more information we have the better we can help you out.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-24-2009, 10:54 PM
chucky123 chucky123 is offline
Re: smoking black 99 gst w 6bolt
black smoke is usually overfueling. is the air filter clean. you are losing air or overfueling. is the check engine light on. i think if you have a bad forward 02 sensor it will overfuel and run rough, or if your cutting off the air. is the car turboed, if so i think you may not be getting enough boost. hopefully i could help
Old 11-25-2009, 10:42 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Boost leak? It'll act just like that...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-26-2009, 01:01 PM
Exclamation Re: smoking black 99 gst w 6bolt
well the car is a 98 model gst the motor i put in is a 6 bolt what i did to it was i changed the t25 with a 16g and i removed all the plastic pipping and made all metal with a blitz blow off i put the 2gen exhaust manifold the rest is 1gen i changed the tps sensor to the 2gen i added the map sensor to a breather hose to the intake manifold 2.5 down pipe no exhaust..what should the compression be on the engine ...it just killing the gas smoking black at idle..it seems like no power.it lagging in the biggining then after 3000rpm it revs a little quicker...
Old 11-28-2009, 06:03 PM
Re:90 90 90 90 compression on a 6bolt....
ok finally fixed that issue it was simple not so hard i replaced the mass air meter it still smokes just a little but olmost any..before was like a big cloud of black smoke...but it runs good in all but the thing is i got a hold of a compression tester and got 90 90 90 90 is that good enough for this kind of engine 4g63t 2.0 6bolt?
Old 11-29-2009, 11:50 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
IIRC compression should fall between 160 and 180 but either check a Chilton's manual or wait for someone else to come by to confirm/correct.
Please try to use atleast subpar grammar...its a pain in the ass trying to read some of the garbage people write sometimes.
EX.
iirc comp test shuld b 160 or 180 but try lookin in a chiltons manual or wait for some1 else 2 correct me or agree w me.
See what I mean?
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 11-29-2009, 06:56 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Time to rebuild that motor. at least they are all the same
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-12-2009, 07:02 PM
what might be the problem if compression reading r 90 90 90 90 .. ??well just got a head new valves valve seals done at machine shop ...is there a way to check the block??/the head should be 100% but i dont know about the block...should i put cooolant in the cylinders and wait 2 c what happens and how long??? ALSO CAN I USE 2 GEN PISTON AND PUT THEM ON THE 6 BOLT WHAT WOULD HAVE TO BE DONE ??
Old 12-13-2009, 10:01 PM
Holset powered 420a
Since you just put the rebuilt head on there I would suggest checking timing. If the cam is off even 1 tooth it can drastically decrease compression in all cylinders. Do another compression test and this time check it first. Then dump a capful of oil in the cylinder and it compression raises then your rings are worn. The block should be fine but will need to be honed at the very least and possibly need to be bored if the cylinder walls are damage or out of spec. Do not put coolant in your cylinders!
98 Eclipse GS Turbo
2001 BMW 325i - DD
