Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 11-23-2009, 11:42 PM
bowhuntrrl bowhuntrrl is offline
Transponder key programming procedure ??
I did a search but all I found were dead links. The car is a 2002 Concorde Limited. If anyone has the programming procedure I would appreciate it. I have 2 good keys and want to program a 3rd key for a spare. Thanks.
Old 11-26-2009, 12:01 AM
Scotty89's Avatar
Scotty89 Scotty89 is offline
Re: Transponder key programming procedure ??
Here is what i found on the procedure, Hope this helps!
Two programmed sentry key transponders are included with the Sentry Key Immobilizer System (SKIS) when it is shipped from the factory. The Sentry Key Immobilizer Module (SKIM) can be programmed to recognize up to six additional transponders, for a total of eight Sentry Keys. The following “Customer Learn” programming procedure for the programming of additional transponders requires access to at least two of the valid Sentry Keys. If two valid Sentry Keys are not available, Sentry Key programming will require the use of a DRB III® scan tool and the proper Body Diagnostic Procedures Manual.
CUSTOMER LEARN
  1. Obtain the additional Sentry Key transponder blank(s) that are to be programmed for the vehicle. Cut the additional Sentry Key transponder blanks to match the ignition lock cylinder mechanical key codes.
  2. Insert one of the two valid Sentry Key transponders into the ignition switch and turn the ignition switch to the ON position.
  3. After the ignition switch has been in the ON position for about three seconds, but no more than fifteen seconds, cycle the ignition switch back to the OFF position. Replace the first valid Sentry Key in the ignition lock cylinder with the second valid Sentry Key and turn the ignition switch back to the ON position. Both operations must be performed within 15 seconds.
  4. About ten seconds after the completion of Step 3, the VTSS indicator LED will start to flash and a single audible chime tone will sound to indicate that the system has entered the “Customer Learn” programming mode.
  5. Within about fifty seconds of entering the “Customer Learn” programming mode, turn the ignition switch to the OFF position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the ON position.
  6. About ten seconds after the completion of Step 5, a single audible chime tone will sound and the VTSS indicator LED will stop flashing and stay on solid for about three seconds to indicate that the blank Sentry Key transponder has been successfully programmed. The SKIS will immediately return to normal system operation following exit from the “Customer Learn” programming mode.
  7. Go back to Step 2 and repeat this process for each additional Sentry Key transponder blank to be programmed.
If any of the above steps is not completed in the proper sequence, or within the allotted time, the SKIS will automatically exit the “Customer Learn” programming mode. The SKIS will also automatically exit the “Customer Learn” programming mode if it sees a non-blank Sentry Key transponder when it should see a blank, if it has already programmed eight valid Sentry Keys, or if the ignition switch is turned to the OFF position for more than about fifty seconds.
Old 11-27-2009, 12:05 AM
Scotty89, thanks. I will try that procedure.
Old 11-27-2009, 10:50 PM
Scotty89's Avatar
No problem. Let me know how it works for ya.
