Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 11-23-2009, 06:03 PM
eric1h eric1h is offline
BAck to the Dyno! Ls1 update pics!
Off I go, wish me luck!!
Like my accusump mount? :-D
New PCV catch can
Accusump setup
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 11-23-2009, 07:55 PM
PanozDuke PanozDuke is offline
Re: BAck to the Dyno! Ls1 update pics!
That looks awesome. Video with sound coming?
I need to get one of those Accusump mounts you got there.
Mike
Old 11-23-2009, 09:22 PM
NZGTRA17 NZGTRA17 is offline
Eric, do you have 1 or 2 clamps on the Accusump? One thing to watch for with Accusumps is to not put to much pressure on the clamp/s as it squeezes the tube and slows the internal pistons travel/responsiveness. Last one I used I clamped it at either end so the clamps were bearing mainly on the tube end fittings.
Great to see that you have the beast ready to rumble Eric and look forward to hearing what sort of numbers it punches out. Also looking forward to hearing what you car weighs now with the LS motor.
Good luck, Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 11-23-2009, 10:41 PM
Good luck, Kel.
Thanks Kel, I have 2 clamps, one at each end just as you stated.
Hopefully all goes well, I'm a bit nervous!!!
Old 11-24-2009, 07:01 PM
So the initial report is good/bad.
The good.... they said the car is running great! Still have some tuning to do, they had to order a couple new jets for it.
The bad... the power is down a little than i expected @ 369whp, not sure on torque yet, the top end power seems to be hurt by the crappy short tube headers, and would have been better to use a single plane intake manifold...
but its a lot better than it was and i have some areas to improve on, but i'll take reliable over fast!
Old 11-24-2009, 07:27 PM
Good to hear the car ran well Eric. At what rpm was the 369 peak power? What sort of dyno was it run on (i.e. Dynojet or other)?
Kel M
Panoz GTRA #17
New Zealand
Old 11-24-2009, 07:34 PM
Dawgfan Dawgfan is offline
Eric, how much beefing up did you have to do to the front end for the extra weight and torgue?
Old 11-24-2009, 07:40 PM
I have no idea, I have not seen any of the graphs, I dropped the car off and they are tuning it. I will pick it up tomorrow and i'll have more to report then....
I dont even know what kind of dyno it is, they are a reputable chevy tuner here though.
Old 11-24-2009, 07:43 PM
The process was very complex...
Step 1 remove old engine
Step 2, insert new engine
Step 3 Save 185lbs and add @100hp
The ls1 is lighter and cheaper to add power and should be as, or more reliable. no reinforcing is necessary, my car already has all the GTS chassis bracing plus some!
Old 11-24-2009, 08:04 PM
I know that I have been told that my WC car will have to have a cross brace and maybe more chassis work to handle the torgue???
Old 11-24-2009, 08:09 PM
SOme of the WC cars have the GTS bracing, some have some, and i guess some have none. hard to say.... but the GTS is 450hp stock so if you have the same bracing as a GTS(search for the thread here) then it should not need any extra. Anythig more than 450-500 and you will have to start worrying about chassis flex
Old 11-25-2009, 09:07 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Our GTRA has all the GTS bracing... odd that the WC doesn't.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
