Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 11-23-2009, 05:50 PM
eric1h eric1h is offline
oil cooler in/out?
Does it matter? There is no "secret check valve is there? lol
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 11-23-2009, 07:11 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Re: oil cooler in/out?
Why would this question, just now come up?
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 11-23-2009, 07:19 PM
Re: oil coller in/out?
Just double checking EVERYTHING before i go to the dyno and try to blow up ANOTHER motor! better to ask now, than tomorrow after something bad happens? right?
Old 11-24-2009, 03:41 PM
Gatorac's Avatar
Gatorac Gatorac is offline
It depends on how your oil cooler is mounted. The idea is to make sure it fills completely. If it's standing on one end, the bottom fitting should be the inlet. This way the cooler fills all the way up before oil comes out the other side. If it's mounted horizontal, the fittings should be on the top and it doesn't matter wich is in or out.
Make sense?
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 11-24-2009, 05:32 PM
panozracing's Avatar
panozracing panozracing is offline
Jim that makes sense except the setrab coolers that I thought we all have, have the in and the out on the same side so the in should be on the bottom and the out on top? I will have to check mine I dont think we did that....hmmmmm
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 11-24-2009, 06:15 PM
Gatorac's Avatar
In on bottom-out on top. Think about the oil running through the cooler. What would happen if the inlet was on the top? We want maximum cooling. For that to happen the cooler must be full of oil.
Come to think of it, I haven't ever checked how mine is plumbed.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Old 11-24-2009, 06:53 PM
Thanks
