Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 11-23-2009, 01:49 PM
deadlysyn08 deadlysyn08 is offline
Exclamation 1998 Neon Rough Idle/trouble code p172
Ok, so I recently discovered that my 98 5spd neon was running a little rough, it sounds like its cammed when it sits at idle and if i'm traveling and push the clutch in the rpms drop to 500 for a second or two and then come back up to 950-1000 and idle rough in that position. I have already changed plugs, wires, fuel filter, and fuel regulator. The engine also threw a trouble code p172 (too rich bank 1). Any help on this would be great....she gets me back and forth to school and i cant afford to be driving a dying car!
Old 11-24-2009, 11:20 PM
hundahunta hundahunta is offline
Re: 1998 Neon Rough Idle/trouble code p172
checked fuel pressure, engine compression.....without a scanner it's hard, a quick scan of the sensor voltages will tell you a lot
