Old 11-23-2009, 12:06 PM
iroc343 iroc343 is offline
Windshield Washer Check Valve?
I have a 95 S10 Blazer. In the line for the front windshield washers is a plastic check valve. Mine is cracked and leaking fluid. Does anyone know where I can buy a replacement? I have searched the internet and come up empty. Thanks for any help.
Old 11-23-2009, 02:45 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Windshield Washer Check Valve?
I do not think there is a check valve in line.
If just plastic connection broke.
Your local parts place should have some plastic vacumn line fittings for wiper/vacumn hose repair.
Splice it back up and see if they work.
Let us know how it goes.
MT
Old 11-23-2009, 05:03 PM
I have temporarily replaced it with a piece of steel tubing, and it works, but I thought I'd try to get a replacement. If it's just a connector they went to a lot of extra expense. The part I'm referring to is white plastic, about 3/4 inch diameter and has 5/32 inch barbs out each end, 1 1/4 inch total length. I assumed it was a check valve. I can't find anything in the GM parts diagrams online. Guess I could go to a salvage yard.
Old 11-23-2009, 05:28 PM
MT-2500's Avatar
AF - Advisor
Never runinto anything 3/4 in or 1 an 1 /4 " long on wasker fluid lines.
Post us a picture of it.
If it works that way I would leave it like that or go to auto parts place they should have vacumn line hose and plast fittings for it.
Good Luck
MT
