Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 11-23-2009, 07:46 AM
tonyjames37 tonyjames37 is offline
Jerking Motion
It started yesterday. I started the car and started to drive then all the sudden like jerking motion. I was going about 20-25 mps. Ive noticed when on the highway at higher speeds no jerking. What is wrong? Anyone have an idea?
Old 11-23-2009, 10:18 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Jerking Motion
When was the last time it was tuned up? Also year of vehicle gives more options to what is wrong
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-23-2009, 10:47 AM
Re: Jerking Motion
the yr of the vehicle is 99-2000 and i dont know the last time for a tune up. I got the car from my dad in Sept.
Old 11-23-2009, 11:31 AM
danielsatur danielsatur is offline
Re: Jerking Motion
How about some new Plugs, Air filter, MAF sensor, and a throttle body cleaning.
Old 11-26-2009, 03:02 PM
The Silver Goat's Avatar
The Silver Goat The Silver Goat is offline
Re: Jerking Motion
What year, how many miles and what's been done to the vehicle as far as maintenance? Could be plugs or a fuel filter...
Old 11-27-2009, 02:18 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Jerking Motion
Happened to me a few times. Sometimes it would go away after a few seconds to a few minutes. That was caused by the plugs getting fouled with fuel. Once it burned off,all was good.
One time, it continuously jerked due to a bad misfire. It was a failed Coil-On-Plug (COP). Replaced that and at the same time, replaced all the plugs and all was well again.
To test for a bad COP, pull the electrical connector off of the COP one at a time. Each time you will hear the engine change RPM and run more rough. That indicates the COP is working. Plug the connector back in and move onto the next one. When you pull the connector of the bad COP, the engine will not change RPM or toughness. That is the bad COP. Remove it, replace it, and enjoy.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 11-29-2009, 07:06 AM
Re: Jerking Motion
Thank for this Blue - I was wondering how to determine which COP had gone bad once it happens. This will work for my 04 GTO as well...
Old 11-29-2009, 11:27 PM
Re: Jerking Motion
By the way, if you don't want to dump raw fuel into your cylinders and cats, you can just pull the fuel injector connector instead of the COP connector. Since they're just as accessible on the 4.6L Modulars, I just pull those instead. Not sure what it's like under the hood of the GTOs.
