Old 11-23-2009, 06:34 AM
bratt bratt is offline
Post head light will not shut off switch problem?
I think my switch on the headlight broke
it will not shut off the head lights
The headlights stay on when car is off and key is out and the switch does not shut off the lights
any help?
1998 cavalier 2.4L
Old 11-23-2009, 05:26 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: head light will not shut off switch problem?
hahaha
J/K, I wouldn't do that.
Look at a wiring diagram and see where they get power from, it could also be the relay sticking.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 11-23-2009, 10:40 PM
which relay is for the headlight?
its not just the headllight its the parking lights too. they will not shut off. I even cut the 4 wires going to the switches on the lever. Did not work
I tried various connecting of the wires and grounding them nothing works
I think I need a new lever but I am not sure yet.
Old 11-26-2009, 12:21 PM
J-Ri's Avatar
Pull the cover on the fuse/relay center, it's probably labeled.. otherwise just pull them one at a time until the headlights go out.
Old 11-26-2009, 03:03 PM
Thumbs down Re: head light will not shut off switch problem?
This is stupid because there are 3 fuses to pull
1 for each headlight
and then the parking lights
then you have to put them back in.
PAIN IN THE BUTT!
