Changing passenger side plugs
Argh! I can't do it! I tried, and just looking at them scares the crap out of me.
My friend did the drivers side, but it got dark too soon.. Right now, drivers side, NGK IX Iridium plugs, and MSD Super Conductor wires, passenger side, cheap wires, and AC Delco 41-906's... I really want to finish this wonderful plug and wire change, but I just can't get the damn wrench in there.. ![]() I'm almost ready to go VICE grips on this sucker.
![]() My one and only car! 1994 Chevy Caprice Classic LS L99 Engine |
Re: Changing passenger side plugs
I am not really familiar with the LT1 but sometimes plugs can be gotten to from the underside of the car or thru the fender well if you remove the wheels. I am sure someone will chime in on the best way to get at those suckers. Also a flex head ratchet and 1" extension along with a universal joint plug socket may make easy work of things. Good Luck
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip, 1989 Mustang LX 5.0 5sp convertible 1992 Camry LE 2.2 1996 Suzuki RMX250 I'm a victim of circumstance [ |
I just got it done. I without a doubt did not route the wires GM had intended. There's just no way without lifting the motor it seems..
But, it's working.. Second but!! I seem to have broke a boot on the #2 wire at the Opti.. Damnit!
removal of the flexible inner fender skirts is also advised so they don't get broken... the plug wires need be routed as oem . if not you are looking for trouble later... |
There was just no way to route them OEM, the wires always end up having extra slack and they hang around anyway...
Oh, and I managed it without removing the tire, so it's not "required".. I just don't have the patience required. Besides, people do OTVC mods and have no problems, not OEM, and I think I may be doing that kinda routing next.
use of this material would be a great way to protect wires when not using the OEM routing . on tire removal the reason I suggested it is because I have a 1996 ...since 1995 nov.. and I did this before...the tire removed is the best most secure way to go...also to check on the other wires/sensors starter connections ...with a vehicle this old the cheap OEM plastic loom turns to dust...must be replaced on plug wires and other wires/hoses.. this is how you can burn up a wire harness easy..by not maintaining the loom coverings,and clearances. |
I installed new looms..
I honestly think this is the last for this car anyway.. It's due to an engine rebuild, and I'm not going to pay for that, just replace the whole car.
since you used new loom where needed you should be good..
![]() I've been able to change mine from the bottom and route new wires from the same place. The #2 and #4 plug wires are not a lot of fun, but it's worth the effort to do it right.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
